Spring Rates
Old Jun 20, 2007 | 04:22 PM
GGRJR's Avatar
Spring Rates
Does anyone know what the staock spring rates are for a 2004 sedan with the standard, non sport, suspension? I am looking at either new springs or coilovers, and would like an idea of how they compare rate wise.
Old Jun 20, 2007 | 04:29 PM
Calvin's Avatar
Overglorified Altima
it's stickied at the top of this forum:
Oem springs
G35 sedan's with non sport
Front: 283 Rear: 308
Old Jun 20, 2007 | 09:26 PM
GGRJR's Avatar
Thanks. Didn't look far enough down the list when I did my search. Now second question, how far can you lower a sedan, without needing to go to some type of camber correction?
Old Jun 20, 2007 | 09:38 PM
tinman143's Avatar
less than .8 inches, you might be aight...there's a ton of stuff on here. type "lowering" or "springs" in the search string .
Old Jun 21, 2007 | 09:41 AM
Q45tech's Avatar
Each inch changes camber ~~ 0.83 degrees..............the question is how far below nominal your oem is.
Don't assume anywhere inside the very wide oem warranty range is ideal.
Tires are usually designed for no more than 0.5 degrees negative camber to optimize braking and life.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
