I would watch the Kinetix - there is a bunch of history, current as well, with their arms breaking and causing accidents, etc.
i wouldn't recommend the cusco's either....they are very limited as with stillen. it's between spc and 350evo. although evo's cost double, it is a better product with zero issues.
Quote:
dont the cusco's have +1 adjustment?Originally Posted by superdds
or is it +0.5? i forgot...
i'd say 350evo and SPL if anything
^^^only +.5
i hear that you can modify it to achieve a greater range but no thanks.
I haven't seen the SPC's at any of the online retailers I've looked at. Can anybody pass me a link? I almost ordered them but after hearing that I'm having my second thoughts. The SPC seem to have problems with the ABS.
Quote:
i ordered my rears from them in march when they had a sale.Originally Posted by fullvietFX
http://www.iapdirect.com/home.php?cat=355
So if you lower your ride and have negative camber, with the SPC fronts giving Camber -1.5 to +3.5 degrees, the "+3.5 degrees" will counter that negative camber which will bring it relatively close to oem spec.... am i correct?
^^^yes you will be within oem specs...however in order to achieve the +3 degree camber you have to use their spacers. arms alone will only give you +1 degree.
^are the spacers the ones in red in the lower left corner of this pic?
Is it only because of being really low that Hero is facing the knocking? I wonder how low he is versus what tein recommends for the front ride height
yes those are the spacers...i believe hero was knocking because he was dropped really low even though he has the revised arms.
^ I gotta find a pic of how low he was in the front... cuz most of the spring setups I see on here arent low enough to my liking
thanks again for always answering my questions lol
Here's pics of mine, a while back with S-Techs - and two different bumpers lol
Attachment 72651Attachment 72652
I guess you can't go cheap when it comes to a car like this. How are the Stillens?
Quote:
Watch out for the spacers - they are known to mess with the ABS and VDC. The speed sensors need to be augmented, as they are spaced out too far as well.Originally Posted by superdds
Usually - unless your tracking the car, your good without them. Only put them in if the alignments can't get where it needs to be.
Rick
