Just bought barely used 06 350z springs/shocks
Old Jul 10, 2007 | 01:17 PM
Jum's Avatar
Jum
Florida G35 Owner
Just bought barely used 06 350z springs/shocks! anything else im going to need?
Old Jul 10, 2007 | 01:25 PM
redlude97's Avatar
rear camber kit probably if you want to align back to sedan specs
Old Jul 10, 2007 | 01:37 PM
Jum's Avatar
Jum
Florida G35 Owner
I would be ok on the shocks/springs for the time being right? what if i dont get an camber kit im on a budget?
Old Jul 10, 2007 | 01:43 PM
Jeff92se's Avatar
Red Card Crew
You will have to use your oem strut caps if they were included. From memory, the Z springs don't lower the car THAT much to require camber correction. But it's about as low as you can go w/o requiring it. So you won't really know 100% until you get it on the rack to see what you camber comes out to.
Old Jul 10, 2007 | 01:44 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
It was right at the limits, but I didn't need it on mine.
& On the front align the toe to .04 max
Old Jul 10, 2007 | 02:54 PM
Q45tech's Avatar
Barely used? how do you know without using a shock dynometer to measure the parameters and testing springs to measure their stiffness. Used is Used.
Old Jul 10, 2007 | 04:50 PM
g35rcr's Avatar
i put in the z shocks and springs...my alignment was in spec even after a year
Old Jul 10, 2007 | 04:52 PM
AgentRice's Avatar
JUM... u dont need the camber kit. u'll be fine
just bring all that **** down to me n mike with some cash and we can install
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
Gip
Aug 24, 2015 05:31 PM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
