Clicking Rear Axle...need more help
Old Jul 22, 2007 | 11:16 PM
G35evolution's Avatar
I did use the search function before posting this. If you read my initial post carefully, you would realize that I was aware of how much information already exists on this topic. However, everyone who experienced this problem seemed to get it fixed while I still have the problem even after taking it twice to the dealership and performing the TSB once myself, which is the difference. I didn't want to waste anyone's time...really. All I needed was a little extra input because I couldn't figure out the cause...that's all. Sorry if it was an inconvenience.
Honestly, thanks for the added info...I didn't realize that you had to apply so much torque to the center axle nut. I only applied the specified amount, which was 177 ft-lbs according to the TSB. I was concerned with damaging the assembly if I over-torqued the nut. Maybe I should add more grease to the outer joint and splines before re-torquing again. In light of this info, I don't think I applied as much as I should have. Thanks again guys for the input.
Originally Posted by Nismo G
Holly ****..!!!!! This has to be the 20th post this month on axel clicking. It amazes me that the memebers on here flame new members for posting threads about intakes and which one is better, but yet we have a thread every other day on this topic and people don't think twice about it.
Sorry for the vent, but seriously what the hell? Use the search function
-Sean
EDIT: The main bolt that you take off first right between the wheel studs you literally need to greese the hell out of that bolt and then use an impact wrench for a good 6 seconds...you shouldn't have it after that.
-Sean
Old Jul 23, 2007 | 09:22 AM
tekknikal's Avatar
i think you have the wrong tsb. contrary to what others are saying i believe you do have to replace some parts. i dont have the tsb on me but there's another that shows you what has to be replaced...its not just a simple lube and retorque
Old Jul 24, 2007 | 12:17 AM
Boostwhore's Avatar
had a clicking noise also..... had the tsb done and it still did it. turns out my rear rotors were warped and was causing the pad to slap the caliper making a clicking noise
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
mtlruss
Dec 20, 2015 01:51 PM
Frostbite91
Aug 20, 2015 07:20 PM
dimentio1
Aug 16, 2015 11:47 AM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
