Just Installed Z Suspension - SLIP & Traction Control Light Staying On?
Old Aug 2, 2007 | 03:48 AM
abailey269's Avatar
I just finished installing a set of '07 Z Suspension on my '04 Sedan and took it out for a spin. For some reason the SLIP and Traction Control light are staying lit up. If i turn the car off, then back on, it will go away for a bit but it seems like as soon as i get on it (above 4K rpms but not spinning the tires) the lights come on. Any ideas as to what the problem is?
Thanks.
Old Aug 2, 2007 | 10:31 AM
MrBillMartin's Avatar
hmm. thats odd. ive had that problem before with my 04x when i was spinning in the snow/rain. they would both stay solid until i shut the car off and turn it back on.
hopefully someone knowledgeable will be able to give you some insight on here.
until then maybe try disconnecting the negative battery terminal overnight. see what that does.
goodluck
Old Aug 2, 2007 | 12:59 PM
sdnpaul5at's Avatar
Make sure your wheel sensors are not disconnected.
Old Aug 2, 2007 | 05:07 PM
abailey269's Avatar
Disconnected both positive and negative battery terminals for about 30 sec. Put them back on and all seems well. I'll let you guys know if the light pops back on. Thanks for your help!
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
