Noob to Suspension
Old Aug 3, 2007 | 01:35 AM
dcityjatt's Avatar
Noob to Suspension
Hi guys,
I want to lower my car, not too much tho, just enough to be noticed.
I dont want to sacrifice the quality of my car's ride. I don't want to be scraping everywhere I go. I want to keep the car functional so that it can serve its purpose (be driveable without having to worry)
What are my options, and what do you recommend?
Old Aug 3, 2007 | 01:52 AM
Gsedan35's Avatar
350z H-tech
Though seeing that you have 20's getting better dampning control by adding in Tokico D-specs would not be a bad idea.
Old Aug 3, 2007 | 01:57 AM
nate4598's Avatar
Tein CS coilovers
Old Aug 4, 2007 | 12:16 AM
dcityjatt's Avatar
how much of a drop can i expect with 350z h-techs, and tein cs coilovers?
Old Aug 6, 2007 | 11:32 PM
Gsedan35's Avatar
350Z H-tech drop on a G35 coupe -.8"/-.6"
Tein CS recommended drop on a G35 coupe -1"/-.7"
Tein CS max drop on G35 coupe -2.5"/-1.5"
Tein CS min drop on G35 coupe +.2"/+.4" (keep in that CS adjust's height via spring preload level's, going higher means more preload)
Old Aug 7, 2007 | 10:35 AM
Q45tech's Avatar
The important things to remember is that the suspension has only two purposes: To support the body and to maintain tires in the optimal position going straight and occasionally turning.
Modifications can at best affect handling [defined as peak G] by a few percent.
Tires are 95% leaving at best 5% for suspension.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
