Stillen STB WITH the engine cover
Old Aug 8, 2007 | 11:21 AM
The_Scooch's Avatar
I've compared the two pictures. I'll stick with my set-up.
Thanks for the picture.
Old Aug 8, 2007 | 11:49 AM
lekker_droom's Avatar
Hey Scooch, any plenum spacer installed as well? I see Motordyne in your sig.
Curious if 5/16 AND engine cover will fit uner the Stillen bar.
Also, did you have to use and spacers for the strut bar itself to raise it?
Old Aug 8, 2007 | 03:46 PM
The_Scooch's Avatar
Yes, I have the 5/16" spacer with an MREV+. The bar barely clears the top of the plenum by a couple mm. Just to be safe, I cut a couple squares of rubber and stuck them to the bottom of the bar and those made contact. With the Stillen engine stabilizer, the engine does not move so it's no problem. I didn't use any spacers to mount the bar.
The engine cover does not fit under the bar, even without a spacer. That is why I cut a space out of it so the bar goes through it. Look at my pic in my first post very closely. The bar is almost flush.
Old Aug 8, 2007 | 04:38 PM
Cool, I lost my spacers that came with my Motordyne and plan on getting the stillen fr strut bar, good to know i wont need them.
Old Aug 14, 2007 | 03:55 PM
The_Scooch's Avatar
pics please
Here you go. Very level with the spring mount mod...
Attached Thumbnails Stillen STB WITH the engine cover-g35-profile.jpg   Stillen STB WITH the engine cover-g35-front-angle.jpg
Old Feb 12, 2019 | 02:02 PM
A1 snday1's Avatar
Stillen brake master cylinder brace
Originally Posted by The_Scooch
I installed my Stillen STB this last weekend. To make the engine cover work with the bar, I made a space for it by carefully using a dremel.
Here is a pic for those who might want to do it.
Yo the strut bar you installed, do you know if you are able to install a Stillen Master Cylinder Brace together with the strut bar you installed
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
Team STILLEN
Aug 10, 2015 08:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
