aftermarket pads causing noise...
Old Aug 17, 2007 | 09:56 AM
Smartidiot's Avatar
hello all,
here i have a question regarding the brake..
Sometimes when I hit the brake as i am turning my steering wheel slowly, there is this clanking sound coming from the front end.. at first i thought it was the compression rod that went busted.. but after serveral testing and careful listening.. now i am pretty sure it is the front brake system that is causing this sound..
i brought my car back to the dealer two times in past three months and both times they told me it is because i am usingthe aftermarket brake pads taht don't fit the caliper properly (i bought my 04 G35 auto used in May 2007.. so maybe the previous owner got it replaced with aftermarket pads i think...)... ..and they aint gonna do anything to it sinec its aftermarket parts...one of the service manager even claimed that sinec it is a brand new pad..the pad is too thick to fit in the caliper....all i need to do is to give it some time until the pads gets thinnner then the noise will be gone....i have also brought my car to a local car shop guy and he said it is nothing big deal..,
but i am still kidda worried here as this clanking sound is coming much more often lately....(almost everytime when i hit the brake while turningi the wheel...)...
i did a bit of search on my own on this website and some people mention about the "bed-in" procedure that needs to be done when the pads were first installed.. so i am wondering if this snoise has anything to do with the bed-in procedure that wasn't done properly at the time the pads were installed.. or its because of something esle???
and also.. .is there any ways to fix this problem now??
oh and just for the records, i have a 04 2004 G35 Coupe 5AT non-brembo brake
thank you guys in advance and any suggestions are greatly appreciated..
Old Aug 17, 2007 | 12:10 PM
kvangil's Avatar
Not sure if your problem is the same as mine was, but....When I first installed new rotors and pads (aftermarket), after driving about a month on them, I would get a clunk noise from the front, only when the car came to a complete stop. Dealer said it was because the aftermarket brakes were not OEM fit/finish, and didn't do anything about it. Anyway, about 2 weeks later, the noise went away and hasn't returned since. Wait a few weeks and see if yours improves....Good luck.
Old Aug 17, 2007 | 06:30 PM
Heikes's Avatar
Man, brakes are pretty important. The most important. If it were me, I would at least take off the wheels and make sure all the caliper/bracket bolts are tightened to spec. Last thing you want is a brake malfunction.
Old Aug 18, 2007 | 12:23 AM
gary c's Avatar
Buying a used car........WallMart pads....HAHA
Since you purchased your car used there's no telling what kinda junk someone
installed in place of quality pads......something they picked up at WallMart?
Take it to a quality brake shop and have OEM pads installed. They shouldn't
make noise and will stop you on a dime! It's worth the cost to be safe!!
Old Aug 18, 2007 | 11:59 AM
ISMSOLUTIONS's Avatar
You probably need new hardware kits for your pads/calipers. Happened to me..
Rick
G35VSHNG37
Oct 25, 2015 08:43 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
g35Serge
Sep 30, 2015 11:43 PM
miata007
Aug 17, 2015 04:36 PM
ClwMike
Jul 23, 2015 12:55 PM
