Various Brake Pad characteristics - list yours
Old Aug 28, 2007 | 10:47 AM
darnelled's Avatar
I've seen lots of posts asking about which pads to use as the OEM ones wear down. Mine are getting close to needing replacement too and was wondering if we could get everyone's input on the pads you have and rate them on a scale of 1-10 ( 10 being the best) for the stopping power, dust and noise. All I've had so far are the OEM non-Brembo. Please add where you got them and prices if possible.
OEM 2005 non-brembo
Dust 9
Noise 10 they've never made a sound
Stopping power 8 when new dropping to a 3 after a couple of months
Old Aug 28, 2007 | 11:05 AM
Noremac's Avatar
OEM 2004 non-brembo (sedan)
Dust: 3 (poor)
Noise: 3 (initially OK, but after a few k-miles, sounds like a school bus coming to a stop)
Stopping power: 8 (very good, after you get used to the grabbiness)
Old Aug 28, 2007 | 11:08 AM
Noremac's Avatar
Hawk HPS on 2004 non-brembo (sedan)
Dust: 8 (very good)
Noise: 9 (after 1k miles, zero noise)
Stopping power: 7 (good, but suffers a little from insufficient cold-grab)
Old Aug 28, 2007 | 05:26 PM
The HACK's Avatar
'04 350Z non-brembo (figure it's the same system anyway)
Hawk DTC 60
Dust: 4
Noise: 3
Stopping Power: 9
Cobalt Friction XR-3 (this is on my BMW so take it with a grain of salt)
Dust: 2
Noise: 2
Stopping Power: 11
Old Aug 28, 2007 | 05:42 PM
Texasscout's Avatar
2005 MT6 Sedan
Stock brakes were the BEST! Hardly ANY wear (>2mm) on the pads and virtually NONE on the rotor + NO DUST! (45000mi)
EBC "Green Stuff" pads installed at 45K. They work great but are eating the rotors alive and give off a bit of dust.
Old Aug 28, 2007 | 10:23 PM
obender66's Avatar
Axxis Ultimate
Dust-1
Noise-7
Wear-9(considering track days)
Braking-7
Fade resistance-7
I will not get them again mainly because of dust.
Old Aug 29, 2007 | 09:13 AM
fortified's Avatar
Stock 04' non-Brembo (replaced under 'brake warranty')
Dust-3
Noise-5
Wear-7
Braking-8
Fade resistance-OK for panic stop. Not sure about continuous use (mountain passes, etc.)
Old Aug 29, 2007 | 09:17 AM
Hi-TechG35's Avatar
Stock 04 Brembo Pads
Dust-lots of it
Noise- None
Wear- a little bit.
I recently switched to the Axxis Pads and love them. They are very quiet and have very low dust. I probally wipe my wheels down once a week compared to twice a week with the OEM's.
Old Aug 29, 2007 | 10:15 AM
G35fromPA's Avatar
Stock 04 Brembo pads:
Dust - 10
Stopping Power - 10
Cold bite - 10
Fade resistance - 8 (I have only auto-xed the car, not tracked it, and haven't faded 'em yet)
Noise - 3 (mostly only when reversing, otherwise pretty quiet)
Wear - 7 (front pads have 25% left at 16k miles)
Will likely replace with OEM Brembo pads when the fronts are gone because they stop so well and have such great initial bite characteristics. I can live with the dust - comes with the territory. Brake pads are a tradeoff. If you want low dust and high fade resistance (in other words, a higher temp pad) you will give up some initial bite. If you want great cold bite, you give up some fade resistance and dusting.
Jiggerjuice
Oct 5, 2015 02:33 PM
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
