Sway bar question
Old Sep 12, 2007 | 01:33 PM
  #31
G SEDAN's Avatar
stillen sways do not come with bushings. however, you can order them with your kit through them and they are polyurethane (vs the stock rubber). Some have said the poly. is a bit more stiffer than soft stock rubber bushings. However, if your stocks are not cracked or in bad shape, just reuse them there wont be much difference, if any.
Old Sep 12, 2007 | 01:36 PM
  #32
redlude97's Avatar
The stock "rubber" bushings aren't soft in the normal sense, and are almost as stiff as the polyurethane bushings, and as a bonus don't squeek, so unless your bushings are seriously shot, the OEM's should be fine to use.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
linedr89
Aug 17, 2015 05:11 PM
wuppiedog
Aug 7, 2015 11:16 AM
