Car sags regardless of spring. Any ideas why?
Old Aug 30, 2007 | 04:51 PM
kevmi2ca's Avatar
I've tried 3 different spring sets on my car and the left/rear is always 0.5 - 0.75 inches lower than the right.
What could cause this? Can the spacers wear out?
Thanks.
Old Aug 30, 2007 | 05:01 PM
Glex25's Avatar
Administrator
The driver weight will always make the car sag in the left corner.
Thats why I went with Tein Coilovers so you can have 4 corner independent adjustment.
Old Aug 30, 2007 | 07:53 PM
sliderg35's Avatar
+1 Tein rocks!
Old Sep 3, 2007 | 02:34 AM
kevmi2ca's Avatar
Any way to correct this without going to adjustables??
Old Sep 3, 2007 | 09:51 AM
Q45tech's Avatar
Select a passenger whose weight balances the situation. Honey you must gain 30 pounds?
Unfortunately the world standard for a drivers weight is 150 pounds used to design cars.
Many people are confused by the un mounted stiffness of springs [forgetting the angle and offset distance from the hub].
Mounted stiffness generally means the real world stifness is 140-180 lbs per inch on the front.
chinee
Jun 10, 2024 07:48 PM
slider_ua
Jul 29, 2015 04:17 PM
will091195
Jul 27, 2015 09:19 PM
itschuckster
Jul 25, 2015 08:07 AM
