For what it's worth,
the part numbers for the brake master cylinders are different.
03-04 are different from 05 and up.
Even when you look at them, the brake master cylinder from the 03-04s are visibly larger.
I'm fairly certain when infiniti decided that they would get rid of the higher piston Brembos, they didn't need the higher capacity brake master cylinder.
-DRU
-DRU
took my car to the mechanic, and i had them bled got a little better, put the pedal still goes down alot on initial braking, what else can i do, do you think i need the master cylinder from a brembo car, versus the one that comes on a 2005 with regular calipers.
