Just put on 350Z h-techs/do they settle??
Old Sep 18, 2007 | 11:52 PM
DHCrocks's Avatar
so the 350Z version gives a slightly lower height front and rear then the G35 version of the H-techs?
Old Sep 18, 2007 | 11:57 PM
superdds's Avatar
^^^correct...and the spring rates are more favorable. also, both front and rear springs are linear.
Old Sep 19, 2007 | 04:16 PM
OneManJoker's Avatar
no need for camber kit for the 350z h-tech spings right? cause im planning to get it for my G35.
Old Sep 19, 2007 | 04:21 PM
DHCrocks's Avatar
me too, I'm on the fence. I want a slight drop but only 1/2" or so, no more then 1". driveways are killer where I go. how do you like the ride?
Old Sep 19, 2007 | 04:46 PM
g35brother's Avatar
Does the rear drop at all with h-techs? I'm thinking of just going the revised z setup way if the rear doens't drop on the h-techs. Mild drop and better rates with revised Z springs
Old Nov 18, 2007 | 04:08 PM
John6mt's Avatar
i have the same questions
Old Nov 18, 2007 | 04:11 PM
patman530's Avatar
Z H-Techs will not settle very much at all, so don't hold your breath, what you see is what you get, if you are not satisfied with the rear drop do the springmount mod
Old Nov 18, 2007 | 05:03 PM
surfwb86's Avatar
^+1
There is nothing wrong with the spring mount mod and it lets you get the rear drop exactly where you want it.
Old Nov 18, 2007 | 05:22 PM
tragedycat's Avatar
Springmount mod throws your alignment out of spec though, so don't do it unless you are ready to get a camber kit.
magnetism80
Feb 1, 2019 10:00 AM
brownie
Nov 25, 2015 12:50 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
mikemf8
Sep 3, 2015 08:01 PM
Jadenkid22
Jul 14, 2015 12:33 AM
