Need Advice my G Brothers!! My brakes are acting up!
Old Sep 18, 2007 | 05:14 PM
G37Rider92649's Avatar
Question Need Advice my G Brothers!! My brakes are acting up!
See when i drive and step on my brake pedal, there is no problem, it brakes, but when im driving slow, and im stepping on the brake like half way, (ex: looking for a parking spot.) I hear this clicking or clanking noise, i dont know if its the brakes or not, its not a grinding noise tho, but it only happens when im driving slow and stepping on the brakes slowly half way through then it pops up that clanking noise. It all happened a few days after installing my engine damper but i doubt it has to even due with that? Although everything in the cabin vibrates, everything drives fine, just only when im stepping on the brakes half way while going slow, i hear that noise but it still brakes fine. Anybody have an idea? Thanks for your time guys! Much G Love!
Old Sep 18, 2007 | 11:55 PM
EvolutionGSR's Avatar
Its probably the pads, i think the piece of the pad i'm reffering to is the shim, where there are two holes and through these two holes the caliper pins hold the pad in place. You probably only notice it when you're going slow. Try this, move forward slow then brake, then move backward then brake. You should hear it click. I've been told that its not a problem, unless anyone else here on the forum can tell us otherwise.
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
