D-specs are blown
Old Sep 27, 2007 | 07:12 PM
GeeCoupe's Avatar
D-specs are blown
Feel's like they are blown, I have the 350z d-spec on my 04' coupe; my question is that do I need to replace them with the D-spec or can I go with tokico blue for 350z... 1/2 the price....
Old Sep 27, 2007 | 07:43 PM
redlude97's Avatar
what do you mean they feel like they are blown? When you adjust them, is there a difference in feel?
Old Feb 17, 2008 | 11:24 PM
GeeCoupe's Avatar
I feel a lean on one side, feels way to soft..
Old Feb 19, 2008 | 03:04 AM
dklau33's Avatar
Pull the suspected blown shock from the car. Compress it by hand. If there is no resistance and you see oil leakage on the outside of the shock casing then it is blown. If you replace your shocks you need to replace all 4. Mixing and matching D-specs with the Blues is not a good idea.
Old Feb 20, 2008 | 02:08 PM
Q45tech's Avatar
Measure shocks on application spec shock dyno. Because shocks can weaken without external leaks.
http://www.shockdyno.com/
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
DRG35R
Sep 16, 2015 05:33 AM
Eomfd
Aug 29, 2015 12:42 AM
