Tein H-tech OR Tein S-tech
Old Oct 4, 2007 | 08:06 PM
  #31
Meth68's Avatar
Espresso & surfwb86 do you have pics of your drop? I am interested in htech's for the front and was wondering how much of a drop you guys got and would you say the ride has changed?
Is there an option where I wont need any camber adjustments and getting just a 1" drop from just the front end?
Old Oct 4, 2007 | 08:17 PM
  #32
redlude97's Avatar
Originally Posted by Espresso
For all those with coupes, the safe route is with 350Z H-techs. The better looking route is going with 350Z S-techs. Both drop the car very similar in the front but with the H-techs, the rear still leaves a gap that the S-tech can eliminate. The issue with using S-techs is you will definitely be required to get a camber kit thus resulting in higher cost overall. I have the H-techs and I'm satisfied for now. If I had the chance though, I'd probably would have gone with the S-techs. A simple solution for me now is doing the spring mount mod and getting a rear camber kit.
The problem with that route is the super low springrates the g35 s-techs have which will result in poorer handling compared to the 350z h-techs with the springmount mod. If you are going to s-techs, get the 350z s-techs, and expect more drop
Old Oct 4, 2007 | 08:47 PM
  #33
05skyline's Avatar
+1
Lets see some pics of that drop with the H-techs and how much of a rear gap it has. Thanks!
Old Oct 4, 2007 | 09:27 PM
  #34
redlude97's Avatar
z htechs are ~.8"F G stechs are ~1" Z stechs ~1.2", just install the front springs
Old Oct 4, 2007 | 09:55 PM
  #35
bigc's Avatar
Wings Nation
redlude, as the Springmount Modder-ator, I have a quick questions for you:
If someone has 20x10 rear wheels with +30 offsets and 275 series tires, do you think it will be necessary to roll the fenders if you're dropped on 350z Htechs AND do the springmount mod?
I'm planning to do the springmount mod, but don't want to mess around with the springmount mod if its going to lower the rear to the point where I have to roll the fenders. Any advice is much appreciated. thanks man.
Old Oct 4, 2007 | 10:06 PM
  #36
redlude97's Avatar
no, that should clear easily in that width and offset
Old Oct 4, 2007 | 11:20 PM
  #37
bigc's Avatar
Wings Nation
you're the man.
thanks!
Old Oct 4, 2007 | 11:59 PM
  #38
Meth68's Avatar
I was looking around and found this..
TEIN S.Tech Lowering Springs (SKP30-AUB00) Infiniti 03-06 G35 (2dr Coupe, V35) Our Price: $156.40
* Avg Lower: F(1.2"), R(0.9")
* Spring Rate: F(358 lbs), R(274 lbs)
How does that sound price wise? With just going with front springs can i avoid going with a camber kit? Also how will the ride quality be compared to stock? Thanks in advance I appreciate the help
Old Oct 5, 2007 | 12:56 AM
  #39
05skyline's Avatar
Redlude97 mentioned on this page (the g35 s-techs have super low springrates which will result in poorer handling compared to the 350z h-techs). As far as the price, I think that is a reasonable price for the S-techs new. You may want to consider getting a camber kit for the fronts with that drop.
Old Oct 5, 2007 | 01:43 AM
  #40
redlude97's Avatar
Those spring okay since he's only going to use the fronts, the rears are the ones with really crappy springrates
Old Oct 5, 2007 | 01:53 PM
  #41
surfwb86's Avatar
This thread has a bunch of pictures of the h-techs and s-techs...
https://g35driver.com/forums/picture-share/156253-s-tech-h-tech-people-lets-see-em.html
Old Oct 25, 2007 | 01:20 AM
  #42
05skyline's Avatar
https://g35driver.com/forums/showthread.php?t=156253
Thanks for all the help. I decide to go with 350z tein H-tech springs. Just got them in this afternoon. Hopefully I will be able to get my alignemnt back to specs.
Old Nov 6, 2007 | 02:43 AM
  #43
Granto86's Avatar
Will 350z htechs be good on my 04 sedan with sport suspension withwitho both stock 17s, and in the near future 19' stern wheels without rubbing?
Old Nov 18, 2007 | 10:25 PM
  #44
Turbo Drifter's Avatar
+1
I would like to know too.
Thanks,
Old Dec 3, 2007 | 06:07 PM
  #45
05skyline's Avatar
For the people who already have the Zhtechs installed, how long did you guys wait before getting alignment? 1 month? Where did you go to get it done and whats a reasonable cost?
