Are spc rear toe bolts needed?
Old Oct 7, 2007 | 11:33 PM
Boostwhore's Avatar
about to install my rear camber kit im curious if anyone thinks i need to install my toe bolts also... I dont see how the toe could be that far off im lowered maybe an inch in the rear....
Old Oct 7, 2007 | 11:38 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you're only lowered an inch, i would say you dont need the toe bolts. But if you want to run anything under -1.0 camber then you're going to need them.
-GP-
Old Oct 8, 2007 | 01:50 PM
redlude97's Avatar
-GP-
+1, the more camber you correct, the more your toe is going to be out of spec. I'm lowered, ~.9", I run -1.6 camber in the rear, and my stock toe bolts were maxed out and I couldn't get back to 0.05 toe in
Old Oct 8, 2007 | 01:57 PM
g35cali's Avatar
im running the eibach springs on my coupe and i installed the arms myself, when i went to try and get the bolts installed the alingment guy said it wouldnt be worth paying the labor to get them installed since it wasnt going to really make a significant difference he was trying to charge me 100 bucks for the install too so i decided to pass on it
Old Oct 8, 2007 | 01:59 PM
redlude97's Avatar
so then what did they set your alignment settings at?
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
si_driver
Jul 14, 2015 12:29 PM
