Help: Wheel locks, dont have the tool.
Old Oct 11, 2007 | 09:25 PM
bigugly78cj5's Avatar
a hammer and chisel works.... depending on your wheel design if u have access to to them u can either cut a slot in them or use the chisel to put a slot in it and tap it around counter clockwise to get it off.....sometimes it works sometimes it doesnt. depending on how tight it was put on...... or the all out destroying them...is a pita without an air hammer.......
Old Oct 12, 2007 | 12:10 PM
Q45tech's Avatar
Locks weigh more than standard lugnuts therefore they will create a minor imbalance in wheels. This should be compensated for in radial force balancing - by using a temporary stick on weight [5-7-14 gram as appropriate] near the lug opening where the lock will always be located, during the Hunter radial force balance test.
A note for those who care about PRECISION.
Old Oct 12, 2007 | 12:40 PM
irishsig's Avatar
I don't know if you have already checked this but the wheel lock key is located with the tire iron and jack, under the floor board of the trunk. It may have fallen under the jack.
Old Oct 12, 2007 | 02:44 PM
G35fromPA's Avatar
Once you get the old set off, get yourself a set of Gorilla small diameter lug nuts:
http://store.summitracing.com/partde...5&autoview=sku
No balancing issues and much more attractive. Also strong as hell.
MsFitFern
Aug 9, 2015 02:58 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
