Sedan drop help pics
Old Oct 16, 2007 | 12:03 PM
03Sg35's Avatar
I own a 03 sedan, currently Im running 350z/coupe springs with 05 350z struts. I dont like my drop in the front I got about .9" with the 350z spring. I want to go little lower to make it look like the rear more, tucked. I was hoping to get some RSR 350z springs .6" front on a 350z so sedan I figure should be 1.5-1.6" now thats a good spring from what I read but Will this larger drop kills the ride quality of the car. Also what spring for the front will give me a 1.3-1.5" drop without killing the ride quality?? Maybe the g35 RSR springs would be better?Any input is welcome
here is a pic of the current drop im running 19", the rear settled in more now, but the front looks the same.
Old Oct 16, 2007 | 12:13 PM
93 til Infiniti's Avatar
I would have gone with the TEIN S-techs. They give you a harder drop up front and guaranteed not to settle.
Old Oct 16, 2007 | 04:07 PM
03Sg35's Avatar
Not a fan of tein
Old Oct 16, 2007 | 08:24 PM
dofu's Avatar
20 Year Member
Tein springs are actually really good. It's their strut towers that suck. S Techs will give you the look you are looking for without coilovers. The front and the rear are even, and barely tucked under the fenders.
Old Oct 16, 2007 | 08:48 PM
da mayor's Avatar
this is a photo w/ 350z h&R springs.... drops very aggressive but the ride is not much stiffer.
Old Oct 16, 2007 | 09:47 PM
03Sg35's Avatar
I was going to try H&R, should I go with the coupe or 350z springs?
Old Oct 17, 2007 | 11:29 AM
Gsedan35's Avatar
G35 coupe RSR springs? No, bad idea because they are progressive springs and worse, aren't really any stiffer then the front Z springs, nothing their to help with the reduction in suspension travel range.
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
RSR G35 coupe progressive springs 1”/1” (should be a 1.5"/1.5" sedan drop)
Spring rates in LBS 315/315
Tein 350Z H-tech's will do all that want. When I ran them as a test, they dropped the rear more then I liked so I installed spacers above the upper spring seats to suit my taste. You'll get a 1.3"/1.6" drop.
Old Nov 18, 2007 | 06:50 PM
geesteezd's Avatar
hey da mayor, what size are those rims bro?
vmcarbuyer
Oct 12, 2019 12:42 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
joedaddy1
Jul 28, 2015 02:58 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
