sways making noise
Old Oct 19, 2007 | 04:34 PM
freak21s2k's Avatar
sways making noise
hi, ive done a few searches and ive found a couple threads talking about sways making noises and most solutions are to grease the bushings. i tried that and i still get an ugly noise. i have hotchkis sways and i have it set on 2(near hardest) in front and Med in rear. the sound is a loud knocking sound whenever i go over a bump or go into my driveway. can anyone help me out? thanks
Old Oct 20, 2007 | 07:21 PM
obender66's Avatar
Check endlink to sway bar nut, it might be loose. Take a wrench to it, because you may not noticve freeplay by hand.
If bar is squeaking, then it's bushing problem, if it's knocking, it is most likely loose hardware.
Old Oct 22, 2007 | 08:09 PM
freak21s2k's Avatar
oh alright. thanks for the advice. ill check it tomarro. hopefully itll stop making an annoying knocking sound. its really P***ing me off. haha
Old Oct 22, 2007 | 08:44 PM
jasoncham2003's Avatar
Sorry if this may be a stupid question but which side of the bushings did you lube? I have known some people to lube the part that sits in the bracket and needs to be the part of the way that meets the inner side of the bushing.
Old Oct 23, 2007 | 01:51 AM
freak21s2k's Avatar
haha yeha i lubed the inner side.
rezendvous420
May 31, 2020 01:26 PM
snic09
Nov 8, 2017 01:46 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
Frostbite91
Aug 20, 2015 07:20 PM
atk08
Jul 30, 2015 03:12 PM
