So, what do i need to change the rotors?
Old Oct 20, 2007 | 12:35 AM
Otacon132's Avatar
I bought stoptech stage 2 rotors for my non brembo coupe, along with HKS pads.
Ill be installing these with my friend's uncle, who is a "mechanic". He rebuilt my friends truck's transmission - so i know he knows what he's doing.
But i know you need to bolt down the bolts to certain torque specs (anyone know what they are btw?), and i need a ..."breaker" bar? - im sure he will know what to do along the way, but what tools should i get to make the job easier?
Ill be doing it on Sunday, so if you guys can get back to me asap id appreciate it! thanks
Old Oct 20, 2007 | 08:43 PM
dothemath's Avatar
Check my thread up in the sticky section. A breaker bar will make the removal of the 22mm front caliper bolts much easier. The space is tighter on the rear caliper and the 19mm bolts. I used a half inch ratchet for the rear and needed a short extension to get around the the suspension. A breaker bar is just a long solid handle with a 90 degree bend at the end with a socket holder...thing really long ratchet that does not..rachet.
Some links
My thread
https://g35driver.com/forums/brakes-suspension/182516-project-mu-rotor-stoptech-ss-lines-nismo-pad-installation.html
Stoptech Front
http://www.stoptech.com/tech_info/ma...A_06-04-05.pdf
Stoptech Rear
http://www.stoptech.com/tech_info/ma...F_05-14-05.pdf
The stoptech threads mention a tools list. PB Blaster made the rotor removal easy for me. The torque for the caliper bolts are mentioned in the directions...but the front was around 95-100ft/lbs and the rears were around 65 ft/lbs. Take you time, read, and you should be fine.
Jiggerjuice
Aug 26, 2015 09:00 AM
linedr89
Aug 17, 2015 05:11 PM
miata007
Aug 17, 2015 04:36 PM
sahizzle110
Jul 29, 2015 11:36 AM
RedBaronK
Jul 27, 2015 03:19 PM
