Brake light under hard braking normal?
Old Nov 6, 2007 | 12:30 PM
Fiveseven's Avatar
yesterday i was forced to do some hard braking to avoid a accident.. in doing so i noticed a minor noise like my ebrake was enabling also i saw my break light turn on.. is this normal?
Old Nov 6, 2007 | 12:45 PM
redwillow's Avatar
20 Year Member
no that is likely your brake fluid low and sloshing around in the mas cylinder setting off the brake light. You prob need new pads.
Old Nov 6, 2007 | 10:53 PM
Fiveseven's Avatar
i had my brake pads changed.. fronts about 3-4 months ago rear about 1 month ago.. maybe they bleed the brakes too much and forgot to refill the fluid is there anyway i can check? the brake light only comes on during HARD braking.. also if i am low on fluid is it ok just to add more from the cap?
Old Nov 7, 2007 | 02:28 AM
gotyamahas's Avatar
only top off fluid AFTER you visually inspect the brake pads....
as the pads wear down the fluid level drops.....
mike730
Jan 12, 2018 04:25 PM
Frankieg35
Mar 20, 2016 09:42 PM
Blakearold
Aug 19, 2015 10:20 AM
sahizzle110
Jul 29, 2015 11:36 AM
Lsantana757
Jul 20, 2015 09:08 AM
