Non brembo -> brembo
Old Dec 10, 2007 | 01:41 PM
louieallthetime's Avatar
If you wanted to put on the brembo calipers what all would you need to make everything work? Just calipers? or lines and new rotors?
Old Dec 10, 2007 | 05:08 PM
g35rcr's Avatar
depends on which model car you have
Old Dec 10, 2007 | 06:59 PM
ttrank's Avatar
Grocery getter
You need rotors and calipers for sure. It is a very good idea to do a set of SS braded lines too.
Old Dec 11, 2007 | 02:56 AM
mxkon's Avatar
Yes it depends on the year of your G. If you have an 06 for instance you will need the rotors, calipers, new brake lines, caliper bolts, not to mention the 04 master cylinder is bigger than the 06 so you will have to replace that in order to get the full conversion and performance,.. I could be wrong but that should be about all.
Old Feb 8, 2008 | 03:20 AM
jesseislil's Avatar
Which G35s come with brembos? I've only noticed them on some coupes.
I have an '05 sedan, what do I need for brembo brake upgrade?
Also, anyone know how an '05 sedan with sport-tuned suspension differs from the base sedan?
Old Feb 10, 2008 | 12:22 PM
sfgr415's Avatar
03/04 6MT coupes
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
nissandrifter32
Dec 22, 2015 04:28 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
alessandro
Oct 8, 2015 09:29 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
