SPC rear camber and toe HELP
Old Dec 13, 2007 | 03:53 PM
tightvpkid's Avatar
I just lowered my car with tein flex and i had..kinetics toe and camber but i guess they are not doing the job. Everyone is saying go SPC. I was wondering where is a good sit eto pick up an SPC kit. Does the kit come with everything i need the camber and toe? Anything else i might need so my rear tires will stop feathering?. Thanks alot...Links would totally help. I see like spc extreme kit etc..and the normal toe and camber kit...which ones do i get? LINKS would be very helpful of where to buy them and what kinds...thanks alot..
Old Dec 13, 2007 | 04:06 PM
tjlazer's Avatar
It comes with everyting you need. You can try to shop for the Eibach kit, as it is made by SPC and can be found cheaper online...
Old Dec 13, 2007 | 04:47 PM
tightvpkid's Avatar
im finding the SPC kits for only 109.00 is this the correct one? Osme are going for like 200 somethign what is the difference and how good is the SPC?
http://www.partshippers.com/index.ph...roducts_id=924
Old Dec 13, 2007 | 05:06 PM
citymunky's Avatar
Wow That's Low
Old Dec 13, 2007 | 06:30 PM
Deepdiver's Avatar
the link says two kits are required to address both wheels (2 x $109 = $218).
Old Dec 13, 2007 | 06:49 PM
redlude97's Avatar
Yep, that price is per side, you need 2. Purchase the Eibach kit from ajusa.com, its the same as the SPC kit and comes with the arms and toe bolts
Old Dec 13, 2007 | 07:41 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Not trying to jack your thread but....
If I lower my car on tein basics. What do I need adjustable camber and toe arms???? or is there more to it?
Old Dec 13, 2007 | 07:44 PM
jdmgee35's Avatar
You'll need both for at least the rears.
Old Dec 13, 2007 | 09:38 PM
fairwaywiz's Avatar
thmotorsports had a good price going on right now... good guys too... just placed my order today id look into them if i were you
Old Dec 14, 2007 | 01:11 PM
tightvpkid's Avatar
Will the SPC camber kit fit an 07 g35 coupe?
Old Dec 14, 2007 | 01:28 PM
redlude97's Avatar
yes
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
linedr89
Aug 17, 2015 05:11 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
