Brake problem..
Old Dec 20, 2007 | 10:35 PM
nyqueenz's Avatar
Brake problem..
I just installed "stoptech" aero rotors, hawk pads and braided lines on my stock brembos..
Went and bleeded the brake system 4 times each cal.. why does the brake peddle still go all the way down felling like I have no brakes??
I noticed on the brembo cals.. they have two bleed off values.. but I only bleeded one on each.. is this the cause of me still having air in my system?
Old Dec 21, 2007 | 09:44 AM
cato's Avatar
SouthernComfort Moderator
You gotta bleed both sides!
Old Dec 21, 2007 | 10:22 AM
Deezflip's Avatar
Yeah, try both sides and make sure you don't run out of brake fluid in the reservoir while bleeding.
It might take more than 4 times if necessary. You can also try the rear if you upgraded those as well.
From experience, try it with the engine running. Vibrations from the engine really gets the air bubbles moving. Just make sure your car is properly supported...jacks stands/lifts/etc.
Old Dec 21, 2007 | 12:08 PM
nyqueenz's Avatar
cool thanks i had an idea that was the problem..
Old Dec 21, 2007 | 12:19 PM
Gilley's Avatar
Bleed the inside first, then the outside.
Old Dec 21, 2007 | 12:52 PM
nyqueenz's Avatar
so basically i have to re bleed all of them again?
Old Dec 21, 2007 | 01:44 PM
Gilley's Avatar
Get a Mighty Vac hand pump from the auto parts store and it's easy. You don't need anyone to pump the brake pedal.
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
