Are Brembo Spec V calipers the same as the Coupe ones ?
Jan 13, 2008 | 01:31 AM
I can get a good deal on them and im wondering if i can throw them on the sedan?
Reply 0
Jan 13, 2008 | 03:02 PM
anyone?
Reply 0
Apr 4, 2008 | 08:10 AM
BUMP , my friend still has the set for sale .
Anyone know about this ???
Reply 0
Apr 4, 2008 | 08:22 AM
If I remember correctly there is some difference, I cant remember what but I think I remember reading that they were different
Reply 0
Apr 4, 2008 | 08:25 AM
they seem to have the same mounting points , im thinking the rotor is a diffrent size tho.
where did you read that ? ive searched and found nothing.
Reply 0
Apr 4, 2008 | 08:28 AM
maybe call brembo and ask?? i dunno..
Reply 0
Apr 4, 2008 | 08:33 AM
I dunno some where over the time of being on this board I think I recall someone asking this b4
Reply 0
Apr 4, 2008 | 11:11 AM
all oem brembo's are unique to the car application with the exception of the 350z/g
Reply 0
Apr 4, 2008 | 11:14 AM
Rotors are definitely different sizes:
http://www.nissanhelp.com/Models/200...escription.htm
Not sure about the calipers themselves though.
Reply 0
Apr 4, 2008 | 12:12 PM
So i called Brembo and spoke with an engineer , a
he said the calipers are slighly diffrent and rotor is totaly diffrent ,
However he said that using the 03-04 G35 rotor and the spec V caliper might work, without testing he is unsure. but because the 03-04 rotor is almost exact size as the G35 NON brembo rotor.
only other route is to do the 350z track swap.
Reply 0
Apr 9, 2008 | 06:39 PM
03-04 g35 non-brembo rotor thickness might be small enough in thickness for the spec V calipers, but it is too small in diameter to be used on the caliper. The biggest problem with the spec-v bremos is that the rotor thickness is nowhere near the g35 brembo's thickness. Also, the spec V sentra rotors are in the 4 lug pattern, so you cant simply use that on a G35. The only solution i see for you, is to find a manufacturer that can drill a spec-v sentra brembo into 5x114.3 to use it on the G35.
Say you were to get it accomplished........you're using a brembo brake kit engeineered for a smaller/lighter car that doesnt have the power as a G35. whether that will affect your safety or not, is completely subjective, but i'd recommend just getting a normal g35 kit used, or another BBK kit for the G. Don't ever scrimp on brakes.
Reply 0
