vibrating at 60+ esec. 80+mph
Old Jan 14, 2008 | 05:41 PM
alpineninfinity's Avatar
Pretty annoying problem. 05 sedan 66k miles, automatic. option B package or w.e. I get vibrating in the steering wheel deff. feels like its in the front of the car because my passengers say they cant feel it really. Dealership said the wheels are balanced but they could just be doing a crappy job. I searched the forums for a while and came up with the possibilities.
inner outter tierod
rear propellar shaft ? what everthat may be.
balancing
warped rotors
steering rack
Any suggestions ? possiby any way i could check some of these things ? I appreciate it guys an girls.
Old Jan 14, 2008 | 06:05 PM
AGThing1227's Avatar
What tires do you have? That can be a big part of it. Have you looked to see yourself if the tires are balenced correctly? Because some places say the balenced them but blow it off(I am not saying every shop does it but some do). There is a little tool to check it with.
Also Are you technically inclined? Reason I ask is because your tires could be misweighed(I don't know the word/phrase sorry). Take a scale to each of the four wheels and lower the car on the scales. I forget the formula of what each tire side/front and rear should be. To correctly do this it takes about 4 hours. This will help a great amount as it did to some of my previous cars. Man, I suck at explaining. Hope I helped.
-AGThing1227
Old Jan 14, 2008 | 06:23 PM
ttrank's Avatar
Grocery getter
Could even be a bent wheel. You can balance the tire all you want and if the wheel has a slight bend it will vibrate.
Old Jan 15, 2008 | 04:30 PM
Q45tech's Avatar
Use a Hunter 9700 radial force balancer to find tire/wheel problems.
Rotor vibrations CHANGE as you apply brakes epeatedly and heat them up.
Old Jan 15, 2008 | 08:00 PM
Never thought of that. I guess check the simple things first.
-AGThing1227
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
5150DS
Sep 26, 2015 07:47 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
