07 350Z Springs on a '04 Sedan
Old Jan 14, 2008 | 05:48 PM
G'ed in TX's Avatar
I've read through the suspension section and Tank's new FAQ's before asking and see answers for older model springs, but essentially,(A) am I going to run into premature wear issues on my '04 non-sport sedan if I put 07 350Z springs on it. I'd like about .5-1.0 inch of drop all the way around to set-it a little more agressively and slightly better handling... (B) Am I going to have any issues (roll fenders/camber kit) if I upgradede rims to 19's or 20's from my current 17's?
Am I on the right track?
Is there a better way that I've missed while searching..And while I know this should probably go in the Suspsension section, I wanted to hit the Sedan owners in particular, so sorry if you have to move it mods...
Thanks Gents
Old Jan 14, 2008 | 06:26 PM
ttrank's Avatar
Grocery getter
It's ttrank (aka - Tim Trank)
A) Yes you will have premature tire wear on the inside from the increased negative camber. A camber kit will help this or you can swap the tires from side to side every ~5k miles and save most of the life.
B) Not if you get the right size and offset wheels.
Old Jan 14, 2008 | 07:40 PM
az1anbeethoven's Avatar
i would get the shocks and springs as a package instead of just springs...make sure its from a 350z 04.5 and up.
As Tim said, the right size wheels, tires and offset and you are going to be fine
jsimonk
Dec 22, 2023 03:49 PM
si_driver
Aug 11, 2015 07:08 AM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
