IS there any coilover kit formy G35x 07?
The AWD setup continues to use a unique front suspension setup vs the RWD cars. Manufactuers have never felt the low production numbers of the AWD vehicles on the road could allow them a large enough buyer base to recoupe their R&D investment of a special front setup, let alone make a profit. All you can do is contract the name brand players and hope. If a no name brand surfaces, buyer beware, get a shock dyno first and show it to someone that knows how to read it before you spend a dime. Koni can make you front shocks for a price, but I see to many unknowns since you have a 07 as a serious roadblock to that.
Hey Gsedan35. I tried PMing you but your are full. Can you check out they dyno on these coilovers. This is the company I am working on for the 04-06 X. Also if they 07 is the same, they can work for them. Here is the link.
http://www.attackracingusa.com/products.html
Umm, if you want to take off the rim, it would probably be easier. If not, might have to jack it up and take shots from under it.
actually, how about the springs? Can i use those eibach spings or H&R like the others G35s do?
cux im not sure are the springs of 35X different from 35S or normal 35.
thanks
Yes you can use the H&R spring and Eibach spring. But you got to ask yourself how low do you want to go. Because if the 07-08 is like 04-06 it will lower the car about half inch lower than it says.
Gsedan35 correct me if I am wrong.
oh so it means the springs are fit for both S and X?
and if it says it can lower 1.5inches, which it actually means it can lower almost 2inches??
is it what you mean ?
Oh man really thanks for your help.
actually where is your car located at ?
oh i just check on H&R. It says the springs doesnt fit for my 35X <it says(EXC: AWD).>
And i tried to check on the coil kit, it doesn't mention it fits or not. It just says for G35 08. So, do you think it fits?
There is no coilover kit for the awd as of right now.
As for H&R say it doesn't fit the X. Got into the 07 section and look at all the X's lowered and see what they are riding on.
Here I helped you.
H&R springs
https://g35driver.com/forums/showpos...0&postcount=10
Here are Tein h-tech made for a 05
https://g35driver.com/forums/showpos...06&postcount=9
Here I helped you.
H&R springs
Here I helped you.
H&R springs
Here I helped you.
H&R springs
but my place is snowing right now, so i will wait to take pix in this weekend for u. sry
one more qs, if i USE the H&R springs as the post u gave me, where can i get a camber kit of my car? cause i know with that low and without a camber kit, my tires will use up sososo fast and the car will get lower and lower and will drive me crazy.
Here I helped you.
H&R springs
Here I helped you.
H&R springs
one more qs, if i USE the H&R springs as the post u gave me, where can i get a camber kit for my car? cause i know with that low and without a camber kit, my tires will use up sososo fast and the car will get lower and lower and will drive me crazy.
