searched DIY springs install = nada...
Old Jan 20, 2008 | 12:28 PM
swapmeet's Avatar
Ok, so maybe i'm a mongoloid... but I can't find a DIY on installing lowering springs.
SO that leads me to believe that either everyone has a shop do it (no way...), or its hidden somewhere and I'm not searching correctly....
Any help would be appreicated.
Just got my G yesterday, and I gotta get'er dropped quickly.
BTW, are the SPC camber arms hard to install????
Old Jan 20, 2008 | 12:50 PM
RiledUp's Avatar
http://forum.g35nyc.com/showthread.php?t=470
Old Jan 20, 2008 | 01:13 PM
swapmeet's Avatar
^^^ Thanks,
That does look easy, he didn't show a spring compressor, but sombody below mentioned it, do you need one?
Also, is the suspenison on a Sedan basicly the same as a coupe...
Old Jan 20, 2008 | 01:26 PM
RiledUp's Avatar
Couple more: https://g35driver.com/forums/showthr...+%2Bcompressor
https://g35driver.com/forums/brakes-suspension-diy/104137-long-overdue-fix-my-diy-suspension-how.html
Pretty sure the second one is for the sedan (OP is Gsedan35), you should be able to figure out if they are different. I don't see why you wouldn't use a spring compressor, you can borrow one for free from Autozone according to one of the above posts. Good luck.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
RA102223
Aug 15, 2015 09:24 PM
yassy
Aug 9, 2015 07:31 PM
papo020
Jul 17, 2015 10:30 PM
