5mm spacers question!!
Old Jan 24, 2008 | 03:59 PM
BLACandBLU06's Avatar
Originally Posted by shogun281
The 10mm are $100-125, But I had a found a good deal for 5mm Eibach's for $60. Plus, I don't know if the 10mm would make my tires bulge out too much.
Are they 100-125 for the set or each?
Old Jan 24, 2008 | 04:03 PM
Jason@Riverside's Avatar
for a pair... 2 spacers...
Old Jan 24, 2008 | 04:18 PM
GThIrtYFiZle's Avatar
I just installed 5mm spacers in the rear. The reason y they dont have the shoulder coming out is because with 5mm spacers installed your wheel will still have enough space to sit on the hub. As a matter of fact I installed 5mm H&R spacers and I still had enough space to put the hub ring on the hub. Theres a reason y 5mm spacers dont have it. RedLude had explained it to me and it was exactly as he said. Trust me youll be fine with them.
Old Jan 24, 2008 | 04:19 PM
redlude97's Avatar
Glad it worked out for you, I knew the hub extended further than 5mm
Old Jan 24, 2008 | 04:21 PM
DRA-G35-ON's Avatar
oh man, between you and Jason I have no idea what to order...
Old Jan 24, 2008 | 04:31 PM
^^ LOL, trust me, I was in the same exact boat as u were. I actually posted pics and everything cuz I didnt kno what to do. I was ready to ship them back and get the 10 as well. But like I said. redlude chimmed in, I gave it a try and it basically worked out perfectly. Ther had to b a reason y the 5mm didnt have the shoulder. Im sure H&R didnt design a spacer czause the wanted it to break lol. I have iForged wheels on, and if I would have put
10mm on they would have sticked out. So I gave it a try with the 5mm and yup, the wheel hub ectends further out then what the spacer covers, which gives u the ability to put on the hub centric ring as well. As long as it has some room to sit on it correctly u are good to go. I will be installing the fronts shortly as well.
Old Jan 24, 2008 | 04:45 PM
DRA-G35-ON's Avatar
^^^^ are you on G35NYC?
Old Jan 24, 2008 | 05:03 PM
Yup^^^^.
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
