Do coupe brakes fit on a sedan?
Old Feb 10, 2008 | 08:13 PM
phast240's Avatar
One of my buddies is parting out his coupe and is wanting to sell me his brake setup. He has cross-drilled rotors and Hawk pads, but I'm unsure if the coupe parts will swap over to my sedan. His coupe is an 03 and so is my sedan.
Any input is much appreciated.
Old Feb 10, 2008 | 08:28 PM
5150DS's Avatar
This is probably going to be moved, but in short; yes they do. Also 350z brakes will work with little modification. If you are going to get brakes from the coupe make sure they are Brembo.
Edit: Sorry, I just read your entire post and not just the title. The brakes should fit, the only problem is the rotor size changed from '04 to '05. Also, if your friend has Brembo, they will not fit.
Old Feb 11, 2008 | 12:33 AM
ttrank's Avatar
Grocery getter
Yes the brakes are the same.
Old Feb 11, 2008 | 03:17 AM
Beebo's Avatar
yuperz they will fit...
Old Feb 11, 2008 | 09:12 AM
phast240's Avatar
Thanks for the help guys, I'll go ahead and pick up the brakes then.
This should be fun...LOL.
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
mushu
Jul 15, 2015 03:55 PM
