Help!! SPC Toe Bolt to Short
Old Apr 1, 2008 | 11:10 AM
vash_g35's Avatar
no need for a template, just make sure that the bolt will be able to twist 360deg after you elonged the hole (towards inside).
edit: make sure you can rotate the toe bolt "with washer" 360 deg!
Old Apr 1, 2008 | 12:32 PM
vash_g35's Avatar
additional info: found these pictures on a different forum when i have mine getting ready to be installed. GL!
picture shown is non RAS. The only diffrence between the one with RAS is a longer toe bolt, but same process
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
