Lowering Car: Fender Roll?
Old Feb 28, 2008 | 06:42 AM
TurboDreamzG's Avatar
Hey guys I just got my basics and I'm installing them next week. Just a quick question. If I drop the ride down about 1.5" all the way around do you think I will need to roll my fenders or modify my body at all. If so then what? I have 19x8.5's in front on 245/35 and in the rear have 19x9.5's rolling on 285/35 help would be appreciated, thanks guys.
Old Feb 28, 2008 | 07:01 AM
Boston's Avatar
I'm on Basics and my rears are 275/30 19x9.5. I have the rear setting as low as it will go and no need to roll the fender. I have an inch gap that I'd like to close up with the spring mount mod at which point I'll roll the rear fender. Do you have a rear camber kit? If not, I'd suggest getting the kit with toe bolts.
Old Feb 28, 2008 | 09:30 PM
06PlatinumG's Avatar
You may not have to roll your fenders with that setup, it all depends on the offset of the wheel
Old Feb 28, 2008 | 09:32 PM
My wheel offset is: +20mm Front and +25mm Rear
Yes I have the SPC Front A Arm kit as well as I'm installing the SPC rear camber arms with the toe bolts.
Old Feb 28, 2008 | 10:00 PM
redlude97's Avatar
19x9.5+25 with a 285/35/19 will not need a roll in the rear
Old Feb 29, 2008 | 06:43 AM
Thanks redlude.....even if i drop the basic to the lowest setting you think I will have to roll fenders then?
Old Feb 29, 2008 | 09:16 AM
GreenGoblin's Avatar
The goblin resurrection
I dont think that you will have to roll them with that offset even at the lowest setting
Old Feb 29, 2008 | 03:23 PM
great. sounds good to me....but if i do there is a simple diy on here if i need a little bit of clearence. thanks for the help guys.
Old Feb 29, 2008 | 03:37 PM
App6MT's Avatar
Littering and...
Maybe I'm retarded but I had to roll my fenders with +20 285/35/19 in the rears. Mind you you have 5mm less than me but what's 5mm? Probably a lot I guess.
Old Feb 29, 2008 | 03:52 PM
shabarivas's Avatar
5 mm = 5/10ths of a centimeter
Old Feb 29, 2008 | 09:14 PM
App6MT's Avatar
Littering and...
I was being facetious.
Or maybe I am retarded.
Old Feb 29, 2008 | 09:16 PM
jserman's Avatar
I have a 1.7in drop with a 285/30R20 and I don't rub and my rear rim is 20x10 with a 20 offset.....
Old Mar 10, 2008 | 11:15 PM
Red_G35's Avatar
+25 in the rear will not require your fenders to be rolled?
Old Mar 11, 2008 | 07:03 AM
Good I'm glad to hear that....i really didn't want to roll my fenders. All I gotta worry about now is all my lights (vdc, slip, abs) coming on the dash when i install the spc kit?
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
bigmike
Sep 17, 2015 01:58 PM
TeamNoSleep
Sep 13, 2015 07:40 PM
philthethrilloh
Sep 9, 2015 01:25 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
