tein monoflex too stiff!!! help!
Old Mar 23, 2008 | 10:54 PM
streetxtreme's Avatar
hi, i have the monoflex made for the nissan 350z installed on my 2004 infiniti g35.
i find that the springs are too hard for daily driving.
do you have another spring that will fit on my shocks that are softer?
can i just buy lowering springs made for the g35 and install them on the monoflex shocks?
i know the rears i can just get any spring and install them since the shock and springs are separate.
but the fronts are a shock / spring unit. so just wondering if a spring like the skunk2 will fit?
Old Mar 23, 2008 | 11:00 PM
Nismo G's Avatar
Buy my comfort sport coilovers and edfc!
-Sean
Old Mar 23, 2008 | 11:25 PM
how much?
how much for just the edfc and shipping to toronto/canada?
Old Mar 24, 2008 | 12:05 AM
5150DS's Avatar
I don't think you can use a progressive spring in a coilover and Skunk2 are progressive.
Old Mar 24, 2008 | 12:07 AM
what kind of spring would fit?
or should i replace it with a coilover sleeve?
GLuXuRy's Avatar
no such thing as too stiff
Old Mar 24, 2008 | 03:38 PM
Nismo G's Avatar
how much?
Not parting out just the edfc. Not sure on shipping to canada ill have to check.
-Sean
Old Mar 24, 2008 | 04:03 PM
kenchan's Avatar
tein should offer serveral spring rates for their coilovers.
check with them.
Old Mar 25, 2008 | 08:49 AM
idrive_MD's Avatar
you can also source different rate springs from Swift...only problem is it sounds like you bought the wrong set of c/o's for your car and should have gone with the comfort specs instead.
I suggest selling and getting something else!
Old Mar 25, 2008 | 11:08 AM
its bearable...but you lose the luxury feel since every crack in the road is felt inside the cabin
the monoflex spring rate is 780, i should've gone with the typeflex which is about 580 area
Old Mar 25, 2008 | 03:53 PM
kenchan's Avatar
are the two model springs compatible?
and yah, for a 3500lbs car to feel luxurious and smooth, you need to be
under 500lbs/in (ideally around 400lbs/in). 580lbs/in is still pretty
stiff especially running higher psi on summer tires.
Old Mar 28, 2008 | 12:00 AM
yeah..the monoflex are liek 780 lbs/in
can i play with the spring preload to adjust the stiffness ?
Old Mar 28, 2008 | 12:52 AM
06PlatinumG's Avatar
You can contact Tein and they should be able to supply you with a 12kg spring. The valving on most coilovers is good for +/- 2kg and the monoflex is 14kg. I wouldn't get the reg flex, most reviews say the monoflex is a better ride due to the better valving. You will still get a firm ride with a 12kg spring. If you want a comfortable ride I would look at selling the Tein and getting the New HKS hypermax III.
Also I would not mess with the spring preload.
Old Apr 21, 2008 | 09:50 AM
oooooooooooooq's Avatar
Nismo G how much for the tein cs and edfc, ill take off your hands for free if you wnat, ill even pay shipping.
Old May 11, 2008 | 01:36 AM
Jamaica2G's Avatar
That's what she said
