Bleeding Question
Bleeding Question
Finally got my 4 piston calipers to go with my OE BBK. However I do have one question. Once I get the time to put these on Which order do I bleed each caliper, or does it make a difference? I have the factory sequence for the order by corner, but each caliper has two bleed screws, one outer one inner. Based on previous experience, I plan on the outer (farthest distance) first, unless some one has a better insight.
ENVautoDetailing.com
Originally Posted by G35fromPA
FSM says, for an '04 coupe with Brembos, the order is:
Right rear brake → Left front brake → Left rear brake → Right front brake
wrong.. wrong.. wrong.. wrong..wrong!
You always bleed the caliper farthest from the MC first...
Its RR.. LR.. RF.. LF
-GP-
-GP-
-GP-
br.pdf
Itdosn't appear to matter. I have readseveral, different opinions and some say inner first some outer. I am going to do the outer first, fartherst from input line.
I'll definitely be poating a write up once I do teh install, hopefully next weekend. Which Z springs are you running and diid you have any alignment issues? I am planning to do my suspension, later this fall. I am either going with teh Bilstein PSS9 coilovers or Bilstein shocks, and some other springs.
Probably won't be able to do my caliper install until May... sucks because I was really wanting to see em on the car!
-GP-
-GP-
Do the factory Brembos have one or two bleeders on each front caliper? My new calipers each have two bleed screws.
i'm glad you picked these babies up bro! You've been talking about em for a long time to go with your OE caliper BBK kit. Should look nice on your sedan (almost identical to mine). Those 350z track wheels should clear these with room for a whole arm to spare lol
