Brake drag quick question
Old Mar 29, 2008 | 02:59 PM
KevinHeld's Avatar
Here's my deal. I have an '05 sedan which I noticed some brake smell the other day when I got out. After some inspection, rotating etc I found the drivers-side rear brake is dragging pretty bad. Seems to me like caliper or parking brake, either being a corrosion problem. I'm just curious if this is a common problem with these cars. There's no TSB about it and it just seems strange that a <3yo car with under 40k would have a piston seize.
My other question is how is the dealer going to try to make this a non-warranty problem? I scheduled an appointment and I'm just trying to anticipate what load of BS they're gonna try to give me. I don't see how the pad or rotor could be causing this issue (its sad when you have to be afraid of your dealer).
Thanks for your help
Old Mar 30, 2008 | 08:39 PM
G35xBlackawd04's Avatar
Today I discovered the exact same problem. I thought I had a tire problem, so I changed over to the summer tires and found out that that was not it. I'm thinking of ordering a caliper from Rockauto.com but I was wondering if it might be the emergency brake hanging up. Let me know what the dealer tells you.
Old Apr 2, 2008 | 10:22 AM
harrisot's Avatar
My 03 sedan just started doing this yesterday. The passenger's side rear brake pads are clearly touching and dragging on the rotor. Squeals like a son-of-a-gun. Since the e-brake is a cable actuated drum, that's not my problem.
It should be sticking slider pins; at least I rate that as more likely than the piston sticking. I'm curious what you guys find to be the cause.
Old Apr 2, 2008 | 11:09 AM
Q45tech's Avatar
Brake pads, caliper pins [greasing], and general caliper cleaning are just owner paid mainteance items.
3 years, 40k? When was your last brake service?
Old Apr 9, 2008 | 03:48 PM
harrisot's Avatar
Just to close the loop, mine was a cut boot and rusted caliper pin. Pads are now worn but work. Surprisingly, no noticable warpage in the rotor.
Since I was the last guy working on my brakes 2 years ago, the onus falls on me.
Old Apr 12, 2008 | 09:57 PM
The conclusion to my story was a frozen caliper. Monro Muffler wanted $850 to replace on caliper, rotor and pads. I ordered the parts from Rockauto.com and paid $200. I fixed it myself and all is good now.
3 months ago, I paid the dealer for new pads and hardware kit. The hardware I removed today was rusty, so I think I got screwed.
Th611
Oct 27, 2015 03:48 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
