350z H-techs
Old Mar 29, 2008 | 11:33 PM
GMoNeYAir23's Avatar
350z H-techs
I am about to purchase Sevas 20" Rims for the summer, and use the stock 18"s w/ snow tires for winter. My main question is if I drop the car using the 350z H-tech springs, will the switch from 20's in the summer to 18's in the winter cause any problems? Should I install the springs and get them aligned w/ the stock 18's on. Or should I put the springs on and get them aligned w/ the 20's on? Also after every summer and winter, will I have to get the car aligned again? Thanks
Old Mar 30, 2008 | 03:15 AM
SteveBlake's Avatar
Nope you shouldnt have any problems and the ride quality is actually smoother than stock except when you go over a REALLY bumpy road. And you should only have to align it, but wait about a month.
Old Mar 30, 2008 | 09:57 AM
You mean I only have to align it when I put the springs on, or everytime I go from 20's to 18's and back?
Old Mar 30, 2008 | 12:17 PM
gteclipse3's Avatar
I just installed the 350z H-tech's. I'm very happy with the ride quality. You shouldn't have any problems when u switch from 20" to the 18''. Here are some pics of the drop.
Old Mar 30, 2008 | 12:34 PM
Thanks...I cant see the pics though becuase it is asking me to log in, is there anyway you can post them up here?
Old Mar 30, 2008 | 02:06 PM
SteveBlake's Avatar
Here ya go G Money
Old Mar 31, 2008 | 10:36 PM
Thanks for the pics..are those 20's or 19's? Did you need a camber kit after the drop?
Old Mar 31, 2008 | 10:53 PM
redlude97's Avatar
If you go 350z h-techs, do the springmount mod as well with SPC rear camber kits, looks much better IMO
Old Apr 6, 2008 | 06:11 PM
New Questions up Top^^^...I probally will do the rear camber kit, is it an easy install?
Old Apr 13, 2008 | 03:03 PM
Need more answers, because I will be buying springs this week, and would like to know if I will have any problems.
Old Apr 13, 2008 | 04:40 PM
Gilley's Avatar
If you don't install front and rear camber kits when you install the springs, you will have problems with inner tire wear.
Old Apr 13, 2008 | 08:09 PM
ye, i'm really questioning whether or not when I switch back to 18's will there be any problems/would I have to do anything?
Old Apr 13, 2008 | 11:01 PM
Gilley's Avatar
The alignment won't change between the 18's and 20's. Choose the right tire size for the 20's and you'll have the same diameter tires as OEM 18's.
Old Apr 13, 2008 | 11:52 PM
And what would the correct size for the 20's be...I was planning on ordering F:245/35/20 and R: 275/30/20
Old Apr 13, 2008 | 11:59 PM
redlude97's Avatar
245/30/20 is the correct front tire size
