Brakes?
Brakes?
Hey, I am looking to get a brake kit for my X sedan, and I have a few quick questeions...
I have the non-brembo brakes, and I wanted to put something a bit bigger on.
Can I get the OEM brembos from the equipped ones and just bolt them on/use some kind of a bracket?
Also, The main reason I'm not just getting a BBK is that during the winter, I want to use my 17" stock wheels for my winter setup, so I need something that will allow my stocks to fit around em, and most BBKs wont...
I also don't have an endless budget, probably under 1500, 2k at most.
Anything that I can do? Or am I stuck up a tree?
Hey i just order some Wilwood brakes. Are you looking for fronts and rears or just fronts. I just order my front brakes. You will not find fronts and rearss for 2k. I think if you go with 13'' rotors then they should fit under 17''. Are you looking for 6 pot or 4 pot? If you find out what you want you can get a price range. Most BBK just bolt right on just like the brembos.
Anybody feel free to correct me.
The two biggest things I'm looking for are that they fit under the stock 17" wheels, and that they're inexpensive. Not necessarily looking for a ton more stopping power, as I'm never going to track my car, just really something that looks better and fills the wheel better.
As for front/back, I'd be looking for both, and pots doesn't really matter.
