Sedan springs on a coupe??
Old Apr 7, 2008 | 06:24 PM
dan|el's Avatar
Ok. So my friend has an 03 sedan and I have an 03 coupe. He has a set of Eibach pro lowering springs and is going to give them to me if they fit. So will they? I know the sedan is not as heavy as the coupe so would that make a difference? Any info would help. Thanks!
Old Apr 7, 2008 | 06:27 PM
Jeff92se's Avatar
Red Card Crew
Um, if you're into that 4 x 4 look, it would work.
Old Apr 7, 2008 | 09:13 PM
EZZ's Avatar
EZZ
there's only a 50 lb weight difference between your cars. Try putting them on and post a pic. I'd be interested in what it looks like.
Old Apr 8, 2008 | 01:40 AM
dan|el's Avatar
care to explain a little more?
Old Apr 8, 2008 | 05:42 AM
HenryLee's Avatar
If your getting the eibach springs then you wont look like 4x4.. but if your putting on his stock springs prepare to ride g35 on high.. thats prolly wut his talking about.. im curious to see what sedan eibach springs look on a coupe..
Old Apr 8, 2008 | 06:01 AM
Jeff92se's Avatar
Red Card Crew
Ah you're right. Sorry to the OP. Eibachs lower the sedan about 1"-1.5"??
so on a coupe, it should lower it 0.5" - 1"?
Basicly whatever it lowers the sedan, minus 0.5" from that. Might not be worth it to you unless you are only looking for a slight drop and the higher springs rates the Eibachs might give.
Old Apr 8, 2008 | 06:32 PM
dan|el's Avatar
sorry if there was confusion. To clarify, he has a set of eibach springs that he is not using and is going to give them to me. So I won't be putting his stock springs on my car, I will be putting the Eibachs on.
Does anyone think the spring rate will affect me that much?
Old Apr 8, 2008 | 07:35 PM
ttrank's Avatar
Grocery getter
Spring rate will be fine. They will lower your car ~0.5" less than the sedan specs.
The weight difference depends on the year. 50lbs is not right, some of the early models were closer to 150-200lbs different.
Old Apr 8, 2008 | 07:56 PM
STOOF's Avatar
lol damn i wanted to see stock sedan springs on a coupe!
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
xplosive1
Aug 1, 2015 03:01 AM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
