GT Spec bar fitment coupe
I have an 03 G coupe and have the front and rear GT spec bars . I know the front will go on with no problem, but I remember that the rear would not fit on my Z with the factory exhaust. My question is will the rear bar fit with the factory exhaust?
PS this is not the Lateral Brace it's the straight one
thanks
thanks
I have both on my 03 sedan. The rear bar comes nowhere close to the exhaust,
I'm pretty sure it will fit your coupe. It is the lateral bar that will not fit around the coupe mid-pipe. You should be fine.
I don't think there are any clearance issues with the GT Spec rear lower tie brace and any exhaust. It's the rear lateral brace that can be an issue. Also, the unrevised front lower tie brace does not clear oil pan spacers or larger aftermarket oil pans.
mine did not fit with my stillen gen2 catback. it was hitting the bar just below the logo and put a serious dent on it. i'll try to dig out my pics, they are in my other computer.
rezendvous420
May 31, 2020 01:26 PM
FS[Canada]: G35 Front Upper Strut Tower Bar
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
