help where is the top of the rear shock mount 2003 g35?
Old Apr 19, 2008 | 04:27 PM
ryan5474's Avatar
Thumbs up Where is the top of the rear shock mount to adjust the dampering on a 2003 g35?
i just put the d-specs in and i cant find the top of the rear shock mount so i can adjust the dampering ????help
Old May 16, 2008 | 10:49 AM
Andy's G's Avatar
bump for a good question, i have same problem with my tein cs kit and want to adjust the rear dampening
Old May 16, 2008 | 10:54 AM
Boston's Avatar
For the rear D-Specs, you have to run an extension cable to either the trunk area or to the rear deck. When I had the D-Specs, I ran the extension adjuster to the rear deck and hid them under the child seat restraint plastic cap. There is a thread on here somewhere showing how to do it. Without an extension, you're not going to have access to the top of the shock. Maybe someone that's still running D-Specs can chime in.
rezendvous420
May 31, 2020 01:26 PM
TWASkyliner
Feb 8, 2020 08:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Chattzx
Jul 17, 2015 11:23 AM
