Cusco Zero2 coilover height adjustment
Old Apr 19, 2008 | 05:46 PM
sroks5's Avatar
I have been searching and searching to find out how to adjust the height on my Cusco Zero2's. Can someone please walk me through the steps. I need to raise it about half an inch. Thank you.
Old Apr 20, 2008 | 12:56 AM
Gsedan35's Avatar
The problem with adjusting height is finding out how much you have to uninstall to get enough pressure off enough parts to allow you to lengthen all 4 dampners. Lengthening the rear dampners is required to set rear spring preload and to maintain proper rear shock travel. Rear height is of course set by adjusting the rear spring. Front height is set only by changing the lenth of the dampner bodies.
Did you install the coilover yourself?
Old Apr 20, 2008 | 12:08 PM
sroks5's Avatar
no i didn't install them.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
