Do Htechs need camber kit?
Old May 3, 2008 | 04:41 PM
SAKEN3.5's Avatar
Hi, I just got a set of Htechs for the G35; I've read around but I'm always confused whether its the Htechs that eventually require a camber kit or the Stechs. So do the Htechs require a camber kit?
Sorry if its a dumb question =[
Thanks XD
Old May 3, 2008 | 04:46 PM
MikeYo's Avatar
you may want to get a camber kit but i know a couple people with h techs who are back in factory spec with a alignment.
Old May 3, 2008 | 05:07 PM
edindaclub's Avatar
I am running H-tech and did an alignment..but I still suggest getting a camber kit..i heard u only need the Rear Camber kit if you only lower with H-tech....I m gonna look for a SPC rear Camber kit soon...
Old May 3, 2008 | 05:20 PM
Q45tech's Avatar
Every spring that lowers the body increases negative camber by the same amount it is a pure function of lowering the body.
Old May 3, 2008 | 05:43 PM
BlueDevilBAMF's Avatar
G35 H-techs or 350Z H-techs? The G35 H-techs are something like a 0.2F 0.3R drop, so you could easily stay in spec with an alignment. With the 350Z H-techs it's 0.8/0.7 drop, so you're close to the point where you'd need one, but it's not going to be really, really negative or anything like that following an alignment. If you decide you need a camber kit, the SPC camber kit (from Eibach) for the rear is relatively inexpensive when you consider how much tires cost.
Old May 5, 2008 | 08:20 AM
reverse's Avatar
Don't open the box! take em back......you will be dissappointed in the drop. It looks ok, but it will leave a 3 finger gap in the rear. The camber isn't that bad on the H-Techs.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
mikemf8
Sep 3, 2015 08:01 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
