Where can I pick up pads for StopTech BBK?
As the title says, where can I pick up some brake pads for the StopTech big brake kit? I'd like to find a place online I can order from.
Are there any StopTech pad suppliers/sponsors (i.e. Hawk, PFC, Pagid, Ferodo) here on driver?
check out rotorsandpads.com. that's where i get my DTC-70's for the ST-40. the ST-22 has the same shape as the OEM brembo's, so you could get those at tirerack.com. (note-you could also find pads for the ST-40 at tirerack.com, but they didn't have DTC-70's)
Originally Posted by drsifu1
ferodo DS2500 pads for the ST-40 caliper cAn be found from me for $175 shipped BRAND NEW!!!
I'm probably going with the ST-60 calipers on the front to improve brake bias, but it doesn't seem like pad selection for the ST-60 is up to 100% yet. I'll probably have to start out with DTC-60 Compounds Front&Rear.
And how about rotors, where can I pick up some spares?
you could pick up rotors from the brake section in the marketplace either here or on my350z. what type of rear setup are you running that would require you to get a 6-pot up front to improve brake bias?
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
