Wilwood Question
Old May 7, 2008 | 10:36 PM
Capthook's Avatar
Wilwood Question
On the right side of my car a noise comes from my brakes. It happens when I first start driving my car. It get worst when i apply the brakes. It sounds like metal on metal. It goes away after a couple of miles. Is this normal or not.
Old May 8, 2008 | 04:42 PM
ResIpsa's Avatar
How long have you had your Willwoods? Mine made a scratching noise when they were new. It goes away after a while.
However, these are very noisy breaks. Better get used to brake squeal!
Also, proper break in is absolutely vital with Willwoods.
Old May 8, 2008 | 05:22 PM
Capthook's Avatar
They are about 2 weeks old. I did the whole bedding thing.
Old May 9, 2008 | 06:41 PM
ResIpsa's Avatar
You may want to pull the wheel off and make sure everything is installed properly. Make sure the hub spins freely.
Also, when you installed them were any shims required? I had the Arizona Z Car kit and shim placement was critical. I had a lot of trial and error until everything moved freely.
Old May 12, 2008 | 09:21 PM
Capthook's Avatar
help
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
