Man another camber thread (but i did research but lil more advice)
Old May 8, 2008 | 05:58 PM
Nijo=Style's Avatar
okay
I just got the (z)s-techs i researched all the camber issues about the Z-techs and how much they lower the car. But now i see all these companies make the adjustable lower control arm kits etc. etc. but now the question wat about the camber bolts (offset bolts) and supposedly they can adjust up to 2.0deg. (corrrect me if im wrong). can i go that route. bring it with in factory spec... and w/o paying $160+ price for the rears camber?
has any1 ran the bolts instead of the arms?
Thanks for ur time in advance
Old May 9, 2008 | 10:30 AM
Q45tech's Avatar
Mathematics, specifically trig allows you to calculate the amount of horizontal movement [offset] required to fix a degree of camber.
Roughly ~~~~1/4" offset will correct 1.0 degrees of camber.
How and if some mod will be sufficient depends on how much you need.
1" of body lowering usually increases camber by -0.8-0.9 degrees.
Does an eccentric bolt offer 1/4" or 1/2" ?
teamghost
Aug 19, 2015 04:01 PM
sahizzle110
Jul 29, 2015 11:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
