I have a bad clunk in my front suspension. Any ideas?
Old May 12, 2008 | 02:05 PM
Kuneff's Avatar
I had a bad clunking in the front driver side wheel area. It sounded liek the strut was lose or broken. It was a very solid clunk. Not anything like a heat shield rattle or any other kinda of rattle, this is a soild CLUNK...
I was wanting to lower the car anyhow, and I have just over 80k miles on the car, so I figured I would go for it all now... I put brand new Struts and shocks, brand new Strut bushing plates, and Tein springs. I also changed my rotors since they were warped. So All bolts are tight on the brakes, all joints, bushings and suspension bolts appear to the tight. The sway bar links appear to be in great shape also.... The steering has no play in it...
I am completely stumped... I don't have any idea what the clunking could be coming from. Are there any notorious issues with the front ends of these cars that I should be looking into????
Old May 12, 2008 | 02:52 PM
Kuneff's Avatar
Anyone ever have a clunking in the front suspension????
Old May 12, 2008 | 04:46 PM
redlude97's Avatar
Check the swaybar endlinks
Old May 12, 2008 | 05:00 PM
Klubbheads's Avatar
99% it is the swaybar endlink. I had mine coming out of the rear and it turned out my endlink had snapped. I went with SPL and the noise completely went away.
Old May 12, 2008 | 05:25 PM
GThIrtYFiZle's Avatar
I think I have the same exact noise. Do u hear it every time u hit ruff roads? Like clunk clink clunk ? lol
Old May 12, 2008 | 06:24 PM
Klubbheads's Avatar
yup, slow speeds with ruff roads was the only time i noticed it.
Old May 12, 2008 | 06:46 PM
Kuneff's Avatar
yeah... sounds like it... BUT we just had the sway bars lose when we dropped the car. The end links were not broken and they looked fine... Is it not easy to see when the link is messed up???
Old May 12, 2008 | 06:47 PM
Klubbheads's Avatar
well mine started that clunking noise and the some time later it just split in half. I got aftermarket sways though on their hardest setting.
They dont have to be broken to make moise though.
Old May 12, 2008 | 07:19 PM
Kuneff's Avatar
so what is the best fix? bushing kit? new end links? or just a whole new sway bar setup? I just hate to spend a bunch of money on a new swaybar setup when I will never push the car hard enough to notice the difference.
Old May 12, 2008 | 07:22 PM
Klubbheads's Avatar
what year is ur car?
Old May 12, 2008 | 07:25 PM
Klubbheads's Avatar
This is for a 05 coupe.
here they are for rear sway endlinks
Here they are for the fronts
Old May 12, 2008 | 09:58 PM
Kuneff's Avatar
03 Coupe 5AT. Would NAPA sell those also?
Old May 12, 2008 | 11:52 PM
Klubbheads's Avatar
I wouldn't think so, go to the dealer and it is usually double the price that was listed in the link.
Old May 13, 2008 | 12:21 AM
Sponger's Avatar
6MT Brembo Coupe
Yup, check the endlink nut. They have a way of working themselves loose. A little dab of Loctite will help too.
Old May 15, 2008 | 01:03 PM
XBrisk202's Avatar
Did you figure out the problem?
I had a clinking noise when I did my suspension. Turned out that the top hat of the strut was loose. could be that if it's not the end link
