question regarding camber and ride height
right now I have the z stechs and front and rear ichiba camber kits. I am thinking about buying coilovers but I was wondering what is the lowest I can drop it and have it still driveable as in steer without rubbing. also I would still need to get them into camber spec for recon permit reasons here.
Basically what is the limit of how low I can go to not max ou the camber kits and also to be able to drive without rubbing while steering?
thanks in advance.
thanks in advance.
The ichiba front camber kits are going to be your limiting factor, they only correct 1/2 degree positive camber which is probably just barely enough to get your s-techs back in spec. What is your current alignment settings?
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
