Brake pad and rotor labor
Old May 21, 2008 | 02:02 AM
GeeCoupe's Avatar
What is a fair labor price to change f/r brake pads and rotors on my 04' coupe (brembo)
Old May 22, 2008 | 03:04 AM
The Critic's Avatar
Most shops go by flat rate, and programs such as All Data, Mitchell OnDemand, etc will list a time for a job. I would guess that rotor/pad replacement would be about 1.5 hours per axle.
Some shops may charge a flat rate for all brake jobs, especially brake/muffler shops, so I'd look into those first. They may be significantly cheaper.
Old May 22, 2008 | 11:34 AM
SukaZenki's Avatar
Depends on which Brands of Pads & Rotors you going with. I have the same year as yours and I have X-Drilled Brembo Rotors and Nismo Pads. Also, your Brembo's will determine which pads you'll be able to fit into it. I wanted to go to Akebono Racing Pads but they were too thick for the Brembos. I've also heard some good stuff on the Hawk Pads. Good luck.
Old May 22, 2008 | 09:15 PM
G35fromPA's Avatar
It's not hard to do at all if you're willing to spend a little time and check out the DIY section.
Old May 23, 2008 | 07:16 AM
vhtran's Avatar
If you're a handy man, then DIY is the good thing to learn. Just make sure everything go back together right and I'll bet you, you will feel better than bring to shop. If bring to shop make sure you tell them to use towels to wrap the calipers b4 they clamp the pistons out for new pads. Bad experience for me getting chipped paint of those Brembos, DIY for me since.
Old May 23, 2008 | 02:24 PM
kvangil's Avatar
Last year, it was $260 for labor only to replace all 4 pads/rotors at my cousin's NTB. Brought my own parts. I paid about $220 with the 20% friends/family discount....I have a sedan, non-brembos though, but not sure if that would really make a difference on labor.
Old May 23, 2008 | 04:58 PM
Meatshackle's Avatar
Deep Sea Moderator
I can't imagine paying that much for that job. I'm sure it's normal but if you DIY, you can put that $260 towards a lot of other things.
It might have taken me 2-3 hours to do the job and that's in a one-car garage with jackstands, no lift. That also included time to clean the inside of all of my wheels. It was probably less than that but I wasn't keeping track.
Old May 23, 2008 | 05:53 PM
nghiars's Avatar
i got a guy that charges me $50 for fronts and $50 for rears.... i got the best mechanic!
it only takes like 30 mintes for front and another 30 for rears... if you have alift and all required tools/parts
Old May 23, 2008 | 07:24 PM
Deep Sea Moderator
^That sounds more like it. Don't lose that guys number!
Old May 23, 2008 | 08:43 PM
nghiars's Avatar
definitely... he does all the work out of his shop and even got me a used OEM toyota previa brake caliper for $40 bucks for my sister
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
bigmike
Sep 17, 2015 01:58 PM
NJ6MT
Sep 10, 2015 08:40 AM
Machine Head
Sep 4, 2015 07:22 PM
